so if i just do it like the pdf it will post correctly for one extruder?
- 3 weeks later...
Hello to you all.
I have also tried to print with Cura on my Creator 3 printer.
I followed the instructions from the pdf file:
https://en.fss.flashforge.com/10000/software/a42243ba68cb81dc8afd7b7fb3e71dcf.pdf
My problem now is that when the printing starts, the second head (on the left) is also activated
and moving parallel with the right head on the bed (picture attached), instead of sitting parked on the left side.
Have anyone else experienced anything similar?
Is there any fix for this? For keeping the left head parked?
Thank you!
George
GregValiant 1,489
Doing some searching and reading it would appear that FlashForge printers can be used with Raise3D IdeaMaker.
The Raise3D IDEX printers use different M605 codes to tell the printer what mode to use and that makes them adaptable to use Cura because they don't require "U" and "V" axes in the gcode.
Your FlashForge might respond to that command or it might have it's own command (I've seen D0, D1 and D2 mentioned). You can check a gcode file to see if something was added to tell the printer which mode to use.
For the Raise3D printers:
M605 S0 is "normal"
M605 S1 is "duplicate"
M605 S2 is "mirror"
It is dependent on your firmware but it's possible that putting one of those "mode" commands (whatever it is for your printer) into the startup gcode and then checking how the printer responds may provide a clue as to what you need to do to keep the left head parked.
Edited by GregValiant
Also, if you made the changes you made (like making it never wait for the hot end to finish heating up) and it still works, it's definitely not playing with standard Marlin. Some of the commands in your example are only in RepRap.
If someone needs
Singel extruder files.
Just remove the .gcode in the filename.
I cant send them as .json
Creator-singel-extruder.... are extruder defenitions
and Creator_Singel_Right/Left is machine defenitions.
Creator-singel-extruder-1.def.json.gcode Creator-singel-extruder-0.def.json.gcode Creator_Singel_Right.def.json.gcode Creator_Singel_Left.def.json.gcode
GregValiant 1,489
@ingo_66 there are typo's in the definition files in the startup and ending gcodes. "singel" is "single".
From: Creator_Singel_Right.def.json. Creator_Singel_Left has the same issues.
"machine_start_gcode":
M118 T0 >>>>>>> should this be "M108"???
107 ; cooling fan off >>>>>>>>>> should be "M107"
M106 S{cool_fan_speed} ; set cooling fan speed >>>>>>>> should be "cooling_fan_speed_layer_0"???
"machine_end_gcode":
G1 G91 E-3 F500 ; retract 3mm of feed stock >>> typo - should be
G91 ; relative positioning
G1 E-3 F500 ;retract 3mm of feed stock
G162 Z F1800 ; home Z >>> OK if the bed drops down. Not good if the nozzle moves down.
G91 ; relative positioning >>>>>>>>> should be "G90 ; absolute positioning ??????
1
3 hours ago, GregValiant said:M118 T0 >>>>>>> should this be "M108"???
That or they forgot to send it to M118 Pn0 T0.
Someone might be interested in that message.
But no, it shouldn't be M108 because that doesn't take a tool number. Or it should be M108 and they need to take the tool number out.
Edited by Slashee_the_CowGregValiant
M118 T0; to my knowledge is Right
M107; Yes
M106 S{cool_fan_speed} ; set cooling fan speed >>>>>>>> should be "cooling_fan_speed_layer_0;
if you like. I,m not sure that i works, but try.
G1 G91 E-3 F500; do you mean that the machine dont accept G1 and G91 on the same line?
G162 Z F1800 ; Bed drops down
G91/G90; Yes
and i'm from Sweden. So singel" is "single 😉
1
GregValiant 1,489
Cura can use special words in the startup and ending gcode and they will be replaced with the value at slicing. The complete list is HERE and "cooling_fan_speed_layer_0" means Initial Layer Fan Speed. If you just have "cooling_fan_speed" the fan could go to 100% right from the start.
(FYI Feed rate speeds in the list are in mm/sec but gcode is in mm/min so they aren't interpreted correctly if you try to use them in your startup/ending gcodes.)
No, you cannot have two commands on the same line. The printer will ignore the line as it will be interpreted an illegal command.
M118 would depend on your firmware. For most firmware it is similar to M117 (send message to LCD) but instead of the message going to the LCD the printer bounces the message back to a print server (like Pronterface).
I have seen this form with M118:
M118 X15.00 Y15.00 Z0.51 T0
That has the bounding box size in and the tool number so maybe it's telling the printer the area where that nozzle should stay. There are no replacement patterns for the XYZ of the model bounding box. It would need to be done in post process.
I've also seen this form using M108:
M108 T0
So use what works.
M118 {X Y Z} (max size of the printed area with object and e.g. a wall) {T0} {T1} {D1/D2}
T0 T1 sets dual extrution
T0 or T1 sets single extrution
D1 sets mirror mode
D2 sets duplicate mode
In these two modes, the print bed origin shifts to 66.5x125, resulting in a print bed size of 133x250 mm.
Creator_Single_Left.def.json.gcode Creator_Single_Right.def.json.gcode Creator-single-extruder-0.def.json.gcode Creator-single-extruder-1.def.json.gcode
1
I so want to point out a bunch of things that would be wrong in RepRap/Marlin but as @GregValiant pointed out, it's probably speaking it's own language.
One warning based on what I do know (so I could be wrong, in which case feel free to ignore me): your machine definition says the language it uses is RepRap (Marlin/Sprinter) so Cura will use what are the correct commands in that when slicing. Many of the commands in your gcode (at least based on the comments) aren't valid in Marlin, so they won't be used in the generated code, or possibly worse, do something different to your expected behaviour (i.e. I see M7 in your startup code... that turns mist cooling on for CNC machines in Marlin, so something completely different). You might have to use one hell of a post-processing script to convert the Marlin into your machine's commands, if the code you're using is what your printer actually uses (i.e. I don't think any valid commands in Marlin start with D, and in RepRap D is used for debugging).
The Creator 3 is a beast 😉
But this works for me.
And as i say in the first post.
"I'm not sure the fan handling is correct, or even matters"
I have very little experience of 3D printers.
But long experience of CNC machines.
3 minutes ago, ingo_66 said:"I'm not sure the fan handling is correct, or even matters"
It can depend on what material you're using, but for some, the fans very much matter. Some need to be cooled ASAP for best results. Some require the opposite. There's a reason people print fan towers.
rburema 26
Thanks for posting this, I'm sure it'll help someone when they search for it.
However;
- It might be possible to do this from within 'vanilla' Cura with a bundled post-processing script, namely (multiple instances of) search-and-replace (one for each substitution). You can get to the post-processing scripts by the top-bar menu: Select 'Plugins' > 'Post Processing', and a window will pop-up.
- The order of the S/T/.., etc. parameters for an M/G gcode line shouldn't matter. Though it appears that it does for your machine. Have you thought about reporting this to the manufacturer?
