I forgot to add that if i use Prusa slicer it works fine. I prefer cura though and would like to use it for use it.
GregValiant 1,317
I haven't seen that problem before. There are currently a couple of bug reports on GitHub involving the "Machine Settings" dialog box, but they have been in regards to the ComboBoxes for "Build Plate Shape" and "Gcode Flavor". Maybe this is another problem with that particular dialog.
I checked using 5.3 and I don't have the problem with the Zheight (but I do have the problem with the comboboxes not actually changing the setting).
Might be a corrupted machine profile..
@Shiler00 can you share a project file with us?
Guide: https://support.makerbot.com/s/article/1667411030205
GregValiant 1,317
@Dustin I get a "Fatal Error" when attempting to open that project file. It appears that there are files involved for his Longer that I don't have(?)
5 hours ago, GregValiant said:@Dustin I get a "Fatal Error" when attempting to open that project file. It appears that there are files involved for his Longer that I don't have(?)
Looks like this project file was generated in 5.3.0 Christmas Alpha.
I think thats why its crashing for us.
@Shiler00 I would recommend reporting your issue over on github as possible bug.
Here: https://github.com/Ultimaker/Cura/issues
- 2 weeks later...
Hello everyone. Thanks for all the suggestions on how to fix my problem. I ended up removing Cura completely and installing 5.3.1.
Working fine now.
- 1
Dustin 144
Can you please tell us what version of UltiMaker Cura you are using?
Also please share your Project file (Directions here: https://support.makerbot.com/s/article/1667411030205)
