Updating a gcode file (G29) and recording it as a gcode one as well ?
Go to solution Solved by rburema,
Posted · Updating a gcode file (G29) and recording it as a gcode one as well ?
  • I have to include a G29 line to my gcode in order to avoid touching the bed each time with too much effort (close to break something).
    But the file I created can't be save in 'gcode' mode, but just in docx.
    How can I have this G29 added while keeping the gcode operationnal for my printer.
    Many thanks,
    Dominique
    • Solution
    If you continue with the manual solution, alter and save the file via notepad or notepad++ instead of word, then save it over the original file.
    Alternatively, you could also probably add a G29 either in a post-processing script (accessible from the plugins top bar menu in Cura), or even in the start gcode, in machine-settings (accessible via the printer/preferences).
    CFFFP_Bouchon de banc de tour G29.gcode
    Sorry to come back with it; here I attached the Cura gcode which is causing me the trouble of 'strong touch' of the bed in all the cases.
    Just I added the G29 code earlier to check bed level before printing but this still not workable as the noze is forced in bed and I have to stop it in emergency.
    Could you check the first lines in order to check my own.
    Many thanks,
    Dominique
    Hi @Domi1958
    I think what @obewan saw was this from your gcode file.
    M82 ;absolute extrusion mode
    G29 ; auto-level
    G28 ;Home
    G1 Z15.0 F6000
    You need to switch the G29 so it is below the G28.
    In Cura select "Settings / Printer / Manage Printer" and in the next dialog select "Machine Settings".
    On the left is the StartUp Gcode box.  You can edit the code in the box so it's like this:
    G28 ; Home
    G29 ; auto-level
    That way the printer will know where the nozzle is before it attempts to level.
