GregValiant 1,044
I see the word "Lattice" in there so I'll assume @GTzxseanxzTG wants all those "window" panels removed.
The short answer is no. The reason is that although you can print the model as a hollow object, mathematically it is sold through and through. It would need extensive rework to be an open frame sort of model.
1
Dustin 55
Im kinda confused.. do you mean like a single wall shell? like an egg?
If so look at the setting called "Spiralize Outer Contour"
