1 minute ago, GregValiant said:It's gone. My understanding is that it was causing more problems than it solved.
OK we're on the same page. But that should mean that travel between support structures is behaving as standard travel.
I am pretty sure that there is no retraction when traveling between two support interface structures though it should (tree supports, different interface extruder or same interface extruder)
Even combing set to not in skin for both extruders, the move is done without any retraction, traveling around the printed part and also over printed parts (though it should avoid printed parts)
I'm fine with removing the feature and keeping the retraction between supports, but it fear it's not the case at least for tree supports with or without different interface extruder.
No problems with normal supports though.
So there's a bug with the tree supports. But the 'limit support retractions' seems to have properly been removed.
GregValiant 1,492
