When you first launch Cura, it walks through a setup process. After agreeing to the User Agreement and clicking next at the data collection notice screen, you have to choose between an Ultimaker printer or a Non-Ultimaker printer. At this point, it tries to autodetect the printer on the network, and failing that, allows for the user to input the IP address.
If the network setup fails or the printer is not attached to a network, you cannot proceed any further, not even slice and save to USB.
I'd be happy to provide log files with some direction, but my network issue is a separate problem and should be in a separate post, or guidance should occur through private messages if that is an option.
Bypass Cura 5.3.1 AppImage setup for Ultimaker printers
I've managed to commandeer a colleague's Windows desktop and there doesn't appear to be a printer setup process post-install. It may be because Cura was installed on this machine once before (but was not at the time of this installation). Unfortunately, I cannot use this machine regularly, so I'll need to either find a way around the post-install setup on Linux or wait for an update that allows the setup process to be bypassed and to be configured manually, later.
On 5/11/2023 at 10:00 PM, celadon_one said:If the network setup fails or the printer is not attached to a network, you cannot proceed any further, not even slice and save to USB.
But you can? You can just scroll down a bit and select a machine to be added locally.
nallath 1,113
I don't know what you mean by "bypassing the setup".
As for the DF signing in not working, if you can provide some log files, I can have a look.
