Objects Shrinking in Vase Mode
Posted · Objects Shrinking in Vase Mode
Hello, I am trying to print a traffic wand for some flashlights using vase mode in Cura. When ever I try to print it  using vase mode the item shrinks  by approximately  9% . Taking the wall thickness into account the item should print  with an outside diameter of  41.8mm but in Vase mode in comes out at 38.2mm.  If I print the object in normal mode it prints at the correct dimension of 41.8mm.  The shrink factor compensations are all set at 100%. The scale factor on the model shows as 100% with the correct dimensions so I do not think I did anything to the scaling of the model either.
I am using Cura 5.3.0 and printing on an Ender 3 V2.
Does anyone have any ideas how to correct this? I know I could manually upsize the scaling until I get a good print but I would prefer to find out what is causing the problem.
        • 56 replies
        • 34 replies
