Horizontal lines (features, holes in wall)
EVO88
Posted · Horizontal lines (features, holes in wall)
Hi!
I do have wired horizontal lines in my prints after a platform is printed or a hole is through the perimeters.
I print with 5.3.1 Version from inside out.
I do have this on different printers, materials and nozzles.
Voron has this issue
Professional printer do have this issue
Prusa has this issue
Bambu does not have this issues???
I just always hear a blame on "hardware issues" including the filament but nothing about the software...
I did a lot of google research but no one seems to know the real root cause of this and how to fix it?
    • 1 month later...
    Hi!
    I would be interessted aswell if you or any of you have a solution
    I have the same problem, even worse on my Ultimaker S3
    Standard AA0.4 Nozzle and in this case Tough PLA White
    Best regards
    Fabio
    I think you are getting either over extrusion on layers with the holes or underextrusion everywhere else.
    1) My guess is speed changes.
    I would mess around with speed changes.  Maybe lower the speed because it has to slow down for those holes as they have sharp corners.
    Or maybe not speed changes.
    2) Maybe it's retraction related as it has to do a retraction to jump across each hole.  Maybe during retraction the filament inside the nozzle heats up a little more and so extrudes a little more?
    Again - lowering speed will help as the temperature of the filament will be more consistent if theory #2 is correct.
    Thanks
    I feel like my speeds are rather slow (see pic.), maybe it's the acc. or jerk aswell
    I'll try messing aroung with the retraction settings.
