Windows 11, Cura 5.3.1 Starts to a white screen...
issacsim
Posted (edited) · Windows 11, Cura 5.3.1 Starts to a white screen...
I am getting white screen and no UI, it's not the dual screen issue and I am on the latest nvidia drivers for my video card.
Attached couple of log files, hopefully someone can help.
One thing to note, Chrome starts doing the same thing if I try to load Cura first. Without trying Cura first, Chrome works fine until I load Cura.
stderr.log cura.log
Edited by issacsim
    • issacsim changed the title to Windows 11, Cura 5.3.1 Starts to a white screen...
    Posted · Windows 11, Cura 5.3.1 Starts to a white screen...
    9 hours ago, Dustin said:
    Did you have some plugins loaded that changes the UI in anyway?
    It looks like lots of your UltiMaker Cura files are either corrupt or missing..
    Would recommend a clean re-install
    Guide: https://support.makerbot.com/s/article/1667337561461
    Thank You @Dustin.
    No luck with the clean install, tried installing as an administrator with anti virus disabled as well, same results.
    I would advise posting this bug (and log files) to Github then for the best help.
    here: https://github.com/Ultimaker/Cura/issues
    Thanks !
    https://github.com/Ultimaker/Cura/issues/15594
    Edited by issacsim
