25 minutes ago, Dustin said:So the red your seeing on the bottom surfaces is UltiMaker Cura telling you where support is needed or recommended (this can be auto generated by the slicer)
The other reason your having issues with this model is because it essentially has zero thickness to it.
You will need to give this shape some thickness to actually print it.
I raised the object to show the red faces off. When I slice the object on the floor it's only able to generate the first 5 layers because of the unresolved issue. I'll attach an image below.
I added thickness in Blender - 4mm. It didn't fix the issue - still claims it's not watertight.
Dustin 55
