When Cura adds the polka-dot pattern to a model it means the model has errors.
That can happen for a number of reasons. In this case I think the 37 separate parts that make up the model assembly have gaps between some of the sub-parts, and the main body. Scaling the model up likely opened up the gaps to the point where Cura can notice them. The result is that if this does slice it will probably be "iffy" to print.
Here I fixed a copy of the model using MS 3D Builder. It's pretty obvious which one was repaired.
This is the repaired model sliced. The original model sliced after I rotated it on the build plate. There are bug reports regarding that behavior, but in this instance I think it is a model problem.
GregValiant 1,320
