Hi there,
Here's the 3mf file/
I have some doubt about the hot end clogging as it happens each time, just before and after the holes
Hi there,
I don't have a definition file for your printer so the file won't open for me as a project. I did get the model though. Both MS 3D Builder and Mesh Mixer reported errors but they must be minor.
Here is the repaired model.
When I sliced the model it looked fine. There were no missing layers. I mentioned a clog only because it's some thing that can happen. Until I changed hot ends and the hot end fan my Ender was notorious for clogging about 45 minutes into any print.
Edited by GregValiant
GregValiant 1,115
That could be an error in the model or the hot end had a clog that cleared itself.
Load the model, set Cura up, use the "File | Save Project" command to create a 3mf file and post the file here.
