Bed Error when using file for post-processing plugin
Posted · Bed Error when using file for post-processing plugin
I keep getting a bed leveling error on my UM5 when i send a file that has a post processing script with it. The script I am using is from the calibration object or the temp tower for PLA. I've tried the same thing with one that isnt sliced with a post processing script and it runs just fine. Is this an issue with the slice or the printer?
    Posted (edited) · Bed Error when using file for post-processing plugin
    You didn't mention which plugin but 5axes is the author of a couple of them.  His screen name here is @Cuq and he may take a look at this for you.  We are into the weekend though so it may not be until Monday.
    In the meantime if you could recreate the exact situation in Cura (same model and same settings) and use the File | Save Project command and then post the 3mf file here he will have something to work with.
    Edited by GregValiant
    Not sure you can use this script with this machine. The Gcode of a UM S5 have some M104 instruction added by Cura and I don't think you can use a temptower postprocessing script in this case. But As I'm not a USer of this machine I cannot comfirm this first analyse.
    Edit :
    UM S5 are using the Auto temperature option so Temperature are modified according to the extruded volume.  The Script doesn't work in this case because the value are also changed by cura.
    Edited by Cuq
    • 2 weeks later...
    I not sure if that it the full reason. I tried the support blocker to reduce unnecessary support on my prints and its given me the same error as the temperature tower. I think either the UM5 or Cura for the UM5 is creating an error when a plugin is used. I will try an older version to check if its Cura.
