Not sure you can use this script with this machine. The Gcode of a UM S5 have some M104 instruction added by Cura and I don't think you can use a temptower postprocessing script in this case. But As I'm not a USer of this machine I cannot comfirm this first analyse.
Edit :
UM S5 are using the Auto temperature option so Temperature are modified according to the extruded volume. The Script doesn't work in this case because the value are also changed by cura.
Edited by Cuq
GregValiant 1,342
You didn't mention which plugin but 5axes is the author of a couple of them. His screen name here is @Cuq and he may take a look at this for you. We are into the weekend though so it may not be until Monday.
In the meantime if you could recreate the exact situation in Cura (same model and same settings) and use the File | Save Project command and then post the 3mf file here he will have something to work with.
