How to retrieve the "currency" symbol
Go to solution Solved by ahoeben,
Posted · How to retrieve the "currency" symbol
What I've tried and hasn't worked are variations on this:
from UM.Preferences import Preferences
currency_symbol = Preferences.getValue("cura/currency", "value")
I often get:
AttributeError: 'str' object has no attribute '_findPreference'
If someone could take a moment to help an old man across the street he'd be much obliged.
    • Solution
    Try this:
    from UM.Application import Application
    Application.getInstance().getPreferences().getValue("cura/currency")
    Preferences is the class, Application.getInstance().getPreferences() returns the single instance of that class that Cura creates. In python, if you call a method of an instance, python "inserts" a reference to the instance as the first argument. Running getValue directly on the class instead of on an instance of the class means that the reference to the class ("self") does not get passed to the method, and instead the string "cura/currency" gets passed as the argument for "self".
    Will you be able to get back to your side of the street later? Or are you planning to stay on this side?
    Thank you kind sir.  That did it.  I can rest quietly on this bench now.
    As for re-crossing I may require help.  I had thought I was crossing Python Street when in reality it is a freakin' 16 lane boulevard and I'm wearing a blindfold.
    The fore-slash in the name just wasn't fair.
    • 2 weeks later...
    Ok @ahoeben I'm trying to get back across the autobahn.
    I'm working on a post-processor and I want to use the extruder_count to enable/disable a setting upon load.
    This requires getting the extruder_count before the settings load and then something like:
    "enabled":  extruder_count >1 ".
    I have made numerous tries.  I believe am now familiar with every error code that Python and QML can throw.  What I have not been able to do is to disable the @#$% checkbox if there is only 1 extruder.
    Any help would be appreciated.
    Share your code (eg github) and I can have a look at what you are doing wrong.
    Have you tried just using the machine_extruder_count variable in the enabled property?
    "enabled": "machine_extruder_count > 1"
    No, silly goose! Using setting names as variables does not work in postprocessing scripts!
    Just to settle this thread...your "shadow setting" works.
    I have once again successfully crossed the highway.
