DivingDuck 105
Most of this was done by @ghostkeeper. Luckily you can find the original documentation at his github repository called SettingGuide in a better readable format here:
GregValiant 1,320
It's the correct verbiage and the correct image. The image has everything it requires except for contrast between the black font and the black background.
If you zoom in really close you will just barely be able to see the words "Gantry Height" written vertically (in black) next to the vertical gray dimension line that is on the right side.
You can make out "Nozzle Angle" as there is some contrast.
The other things that are difficult (almost impossible) to see are "Machine Head & Fan Polygon" which is showing the X width in the top dimension line. "Nozzle Diameter" and "Outer Nozzle Diameter" are horizontal and below the print head, and "Nozzle Length" is the short dimension from the end of the nozzle to the bottom of the print head.
The arrowheads indicating that the gray lines are dimension lines are pretty much invisible.
