Unnecessary movement outside of object
Posted · Unnecessary movement outside of object
I have tried toggling a bunch of different settings, and still have the print head making pointless movements outside of the print area, creating ugly scars on my project. I saw on an older post that they set combing to "Not in skin" and I am still having this issue.
what else could I look at to fix this?
test 76_ pause at 103_0.25mm line_1h40m_CE3S1_gold final test trophy apple logo business.gcode
    • 2 weeks later...
    Hi @dblrnbw,
    Welcome in here.
    There is a lot of questions for you to answer, -if we're posting like this.
    Please attach your project file for this test object. This will give us; what version of Cura you're using, the printer type and the settings used to print your object. (In total, there is more than "30" versions of Cura!)
    This is the best way to have an answer of 3D printing problems.
    Thanks
    Torgeir
    Looks like it was because I had the octolapse set to center the print for every frame instead of not centering it
