I'm not sure if you understood what Dustin said, but the feature you are looking for I'm pretty sure is gone starting in 8.1 firmware. You may want to downgrade your printer firmware to 7.X. Many people have done this. On the other hand, most people seem to prefer the new features in digital factory. Basically many of the features that were available on the LAN are now moved to Digital Factory (the cloud). This is not a business decision so much as a technical decision. The good news is that Digital Factory is free. The bad news is that some companies security departments refuse access so you may have to downgrade which is not trivial. It requires a "firmware recovery", access to the bottom of the printer and so on. Contact your reseller if you want to downgrade the firmware.
1
Dustin 193
Its been awhile since you have updated I suspect?
That was part of the 8.1 update release notes.
The page and a few others are now gone.
You can find past and current release notes here.. https://support.makerbot.com/s/article/1667410781982
d_vee 0
The printer is on firmware version 8.2.0.0. I'm not sure that's the problem. My Cura version is 5.1.1. Could that be the reason things aren't working quite right?
