On the Machine side this was removed in firmware 8.x
You will need to use Digital Factory with current firmware.
"Dashboard" with time in queue and pie-chart of different materials printed
9 hours ago, Dustin said:On the Machine side this was removed in firmware 8.x
Hi Dustin,
Can you detail what subscription level is required for the cloud api access? Does it have to be the top level subscription, or is there some access still on free tiers or is any api access behind a paywall?
Thanks
Scott
- Solution
You can read more about it here: https://support.makerbot.com/s/article/1667337946161
But its Professional - so no, not on free tier.
Enigma_M4 101
it can be found in the web-API, formaly known as "Cura Connect" or "Digital Factory", accessed by IP-adress or via the "Monitor"-tab in Cura.
I don't know, if it's part of the actual S5 firmware, but it's worth a try.
Regards
