5.3.1 doesn't generate support for offset model and moves model
Go to solution Solved by ahoeben,
Posted (edited) · 5.3.1 doesn't generate support for offset model and moves model
To avoid a elephant's foot, a trick I've used in the past is to turn off "drop model to build plate" then lift the model a few millimetres and use support "touching buildplate" to lift the model away from the plate. In 5.3.1, I instead get very strange behaviour: no support is generated and the model is moved and may even be below the build plate. Here's a contrived example where I place the model several centimetres above the plate (Prepare view) and it gets and it gets generated below the plate (Preview view).
Is this a bug? If not, what am I doing wrong?
image.thumb.png.3d3a3bf3ff41881648de950e97d086e8.pngimage.thumb.png.99322e6f09ca1a1e4341927e09985367.png
Edited by StarNamer
fix typos
    • Solution
    Posted · 5.3.1 doesn't generate support for offset model and moves model
    It is a bug, slated to be fixed in Cura 5.4 as far as I know.
    As a workaround, disable supports, then find and unset the "Remove empty layers" setting, and re-enable supports again.
