Is it possible to remove default profiles?
Go to solution Solved by ahoeben,
  • Solution
Posted · Is it possible to remove default profiles?
I a word: no.
Sure, it is possible by altering/removing files, but it would be a very bad idea leading to crashes when loading project files, materials, etc, and you would have to make the same changes again when you install a new version of Cura (or when you reinstall the same version, for that matter).
