Where is the extension ThingiBrowser?
Go to solution Solved by nallath,
Posted (edited) · Where is the extension ThingiBrowser?
I am trying to add the extension ThingiBrowser.
I followed the instructions here:
https://github.com/ChrisTerBeke/CuraThingiBrowserPlugin/blob/main/docs/installation.md#Via-Ultimaker-Cura
But as you see from my screenshots I've had no success.
Has this interesting extension/plugin been removed> ?
Edited by terrypin
    • terrypin changed the title to Where is the extension ThingiBrowser?
    Posted · Where is the extension ThingiBrowser?
    It hasn't been removed and installing it via that way should work (even though the instructions are a bit older / outdated).
    Could you share your cura log files?
    I take it that is the text ile C:\Users\terry\AppData\Roaming\cura\4.12\cura.log, 2 MB with over 7000 lines?
    (You use the word 'logs', plural, but the only other one I have is called 'cura.log.1' and is 25 months old.)
    BTW, the dragging method of attaching files doesn't work here.
    cura.log
    Are you signed in in Cura? I found that to be the problem when I tried what you said; This method works if you are not signed in: you just press the marketplace button up in the top right and search for and install it.
    Edited by FSarndrone
    Thanks. I tried both when signed in and not. I'll have another attempt shortly.
    • Solution
    I think you're just using a too old version of Cura. The thingibrowser doesn't support 4.x anymore. You could try installing an older version (https://github.com/ChrisTerBeke/CuraThingiBrowserPlugin/releases/tag/v2.2.3) should work, but you will have to install that one by hand.
