Always hard to judge an issue from a single screenshot.
You could try setting the "Top/Bottom Pattern" to "Concentric" instead of "Lines".
Any ideas? 😃
Can't tell without a project file.
Load the model and set Cura up to slice. Use the "File | Save Project" command and post the 3mf file here.
GregValiant 1,320
If there is something above that gap then Cura is pulling the skin back to allow infill to continue up into the part.
"Skin Removal Width" and "Skin Expand Distance" effect the gap.
