cura command line error (Windows 11 pro)
navaraj
Go to solution Solved by Dustin,
Posted · cura command line error (Windows 11 pro)
I am trying to use to command line interface for batch processing multiple stl files using the CuraEngine and I am getting this error. This is the command I used to recreate the error
D:\UltiMaker Cura 5.3.1>CuraEngine slice -v -j D:/UltiMaker Cura 5.3.1/share/cura/resources/definitions/creality_ender3.def.json
Is there anything that I can do to fix this error?
Thank you.
    • Solution
    CuraEngine slice -v -j "D:/UltiMaker Cura 5.3.1/share/cura/resources/definitions/creality_ender3.def.json"
    Need to use "" when a folder name has a space in it on windows..
