STLs being exported from Rhino are being significantly rescaled. How to fix?
gr5 2,201
usually this is an inches/mm issue. Even if you develop your model in mm it doesn't matter if rhino is outputting the STL in inches. So two solutions:
1) increase size of object by 25.4X or 2540% in cura - easy to do with the scale tool.
2) Rhino, in it's options somewhere, should allow you to choose "mm" for the unit for STL files.
It's also possible Rhino outputted in cm. In which case you want 1000% in cura.
