Thanks for the suggestion, but the error remains
Could you attach a project file?
Use File -> Save project...; the 3mf you attached in your opening post seems to have been created with File -> export...
A project contains the model and your settings; an exported model only contains the model (geometry).
Here is the file from "save project"
Thank you
- Solution
I don't fully understand why exactly, but lowering the `Maximum Resolution` setting (under `Mesh Fixes`) to 0.2 or lower seems to fix the issue for this model.
See https://github.com/Ghostkeeper/SettingsGuide/blob/48b3c7902c6401cf43fffd14795947c74cd02275/resources/articles/meshfix/meshfix_maximum_deviation.md for more information about the setting
Edited by ahoebenPerfect: problem solved. Many, many thanks for the help.
1
ahoeben 1,845
Reset "Hole horizontal expansion" to 0
