Spiral mode issue
Go to solution Solved by Torgeir,
Posted · Spiral mode issue
Hello everyone,
I want to print a wing I designed in spiral mode. When I choose Surface in "Surface mode" the model looks great, but I want to have a bottom layer as well. When I select Both in "Surface mode", for some reason many lines appear inside the model, which isn't practical for my purposes. Can anyone tell me which setting I need to change so that the model has a bottom layer but it is clean on the inside.
Any help will be appreciated. Thank you!
p.s I use v. 5.0.0 if this will be useful to anyone
Wing Profile STL.stl CE3MAX_Wing Profile.3mf
