22 minutes ago, gr5 said:
If it's ER03 then you might want to buy a heater with a higher wattage rating. Why did you buy a new heater? Where did you get the heater?
Yes it's ER03. I bought a new heater because the old one broke inside the previous heater block. I bought this heater :https://ie.rs-online.com/web/p/3d-printer-parts/9082957
gr5 2,192
Can you say exactly which heating problem you got? The most common are ER01 and ER03 for nozzle heater issues.
If it's ER01 then you have a problem with your sensor.
Also ER03 is common if the heater block is touching the fan shroud. With the print head cool (not hot), try to slip a piece of paper between the olsson block and the fan shroud. If you can't then you need to either loosen and adjust the fan shroud or you need to raise up the Olsson block just a tiny bit. You need at least 0.2mm air gap between the two. Otherwise the fan shroud acts as a huge heatsink.
However if you only get the error with the 0.8mm nozzle then more likely you have a wimpy heater. You can test the heater by measuring it's resistance. The wattage is v^2/R and v is 24Volts so 576/resistance. I believe the standard wattage is 25W and 3dsolex sells 35W as standard heaters and you can also get 40W or 50W heaters from 3dsolex but 35W should be enough for a 0.8mm nozzle when printing at around 30mm/sec. Printing at 200mm/sec with 0.8mm nozzle and 0.4mm layers you probably need a 50W heater.
