Shifting and ugly Print
Go to solution Solved by Carbon,
Posted · Shifting and ugly Print
Hello all
Before I get to my problem, here is the information of the print.
Data:
Printer: Sidewinder X1
Filament is in a dry box with 19 % humidity
Slicing software: Cura
Filament: PETG from 3D Jake 1.75mm
Nozzle 0.4mm
Temp. platform: 75 -80 degrees
Nozzle Temp: 225 degrees
Ventilation off
Print speed 60 mm/s
I have several problems that I can't name but I think the pictures speak a thousand words.
 What can I do about this? Thanks already for your help.
    Hello Carbon
    For this part I used Cura 5.2.2
    I have now installed the new version 5.4.0. Is there a setting there for fixing the problem?
    Thanks for your help
    • Solution
    I had a very similar problem on Cura 5.2.2 upgraded to 5.4.0 and it solved the problem. 👍
