Problemen Cura 5.4 met Ender 3 NEO
Posted · Problemen Cura 5.4 met Ender 3 NEO
Hallo,
Iemand meer problemen met het printen op een Ender 3 NEO of andere ender printer na de laatste cura versie 5.4?
Bij mij skipte het filament steeds en stopte op de helft steeds met printen.
Komt dat iemand bekend voor?
Groet,
Stefan
    All of a sudden I had the problem with every version of Cura, every version of PrusaSlicer, every version of IdeaMaker...every version of all of them.  About 30 to 45 minutes in to any print and the extruder would start skipping.
    My problem was two problems that were stacked on top of each other.  The stock Creality hot end of my 3 Pro AND a bad stepper driver on the 1.1.5 mainboard I had put in.  Having both go at the same time was really hard to troubleshoot.  Fortunately I had the stock mainboard sitting around.  When I put it back in everything became clear.
    Load a Benchy or calibration cube into Cura 5.4.0 and use the "File | Save Project" command.  Post the 3mf file here.
    There should be no difference from 5.3.1 to 5.4.0 regarding extrusions unless your printer definition file was changed.
