Problem at the end of every print
Posted (edited) · Problem at the end of every print
Hi !
At the end of every print I make, the nozzle stops and doesn't go up immediately. So material keeps coming out the nozzle ans this creates this non desirable  over-extrusion. Do you guys have any solution ?
Edited by NaGaNn
    Posted · Problem at the end of every print
    2 hours ago, NaGaNn said:
    Anyone ?
    You will need to provide considerably more information for anyone to offer any useful help for your issue.
    • What model of 3d printer are you using?
    • Have you recently preformed routine maintenance on your 3d printer?
    • What filament type are you using?
    • What version of UltiMaker Cura are you using?
    • Can you share a UltiMaker Cura Project file with us that produces this issue?
    Hi, thank you for your answer, here are more informations :
    - I'm using an Ultimaker 2
    - I did perform routine maintenance recently
    - I'm printing with ABS
    - My version of Cura is 5.3.1
    - I can share a file if you want but this issue is with everything I try to print
    Thank you for your time, i'm not used to forums so I appologize for the lack of information
    UM2_Coupler Cover Plate 73_8mm x 43_3mm v1.3mf
    Edited by NaGaNn
