The color of the imported model in ultimaker cura is black, how to modify the model color
kmimax
Posted · The color of the imported model in ultimaker cura is black, how to modify the model color
After I model with Solidworks, I export the STL file. Then import the STL file in ultimaker cura, the result is black, and the whole model cannot be seen through, how can I change the color in this case?
    Posted (edited) · The color of the imported model in ultimaker cura is black, how to modify the model color
    Cura (normally) uses the color specified in the material. Change the material and it should change the color on the buildplate. What material do you have selected?
    Edited by ahoeben
