Thanks ! Yup but then it actually change the ratio. I can do that even manually, but not what i'm looking for, unfortunately 😕
@MariMakes Sorry to bother you, I don't know if it's a good thing or not to ping you for theses kind of suggest.
Do you know if something like this is coming soon or if it's something that has not been suggested yet ?
Cuq 205
Even if it's not exactly the same thing you can use the Vertical Scaling Factor Shrinkage Compensation to get a part a little bit taller or smaller :
It's not an expansion but a scaling factor.
