Cura slicing a solid
saline
Go to solution Solved by GregValiant,
Posted · Cura slicing a solid
You've got some strange things going on in the corners of the stl which is probably causing this to slice the way it does.
Section of a corner attached.
    The problem was that the fillet was 1mm and the ledge was 1.5mm.  The ledges ran into each other and Cura had a problem with that.  Changed the fillet radius to 1.5mm to match the ledge, and Bob's your uncle.
