Posted · Hotend upgrade V1 to V2
I'm running a 2 Ultimaker original
One has a V1 hot end the other V2
I want to upgrade the V1 hot end as I can definitely see the difference in performance, and I keep getting the odd blockage in the V1.
I don't understand why I cant just change the block tube and nozzle? I find it frustrating that Ultimaker sell a very expensive kit with wood and everything else.
PLEASE could someone explain why and what I need t0 change to get it to perform as the & be a V2 hot end?
It looks like the wood is I have on the block is updated with the curve designs.
Can I just fit https://www.ultimaker.com/products/nozzle & https://www.ultimaker.com/products/isolator-tube
In theory this should improve my retraction, ooze?
Thanks
David (still learning)
    The V2 also has a teflon part which is critical to prevent the blocks you are having. The wooden bits need to be changed for this.
    That's not a v2 hotend is it, the peek is sitting directly on the heater block it looks like, without the gap between?
    yes the peek is straight on the block, no gap, and the nozzle is female..
    sorry cant take a "live" photo till tonight.
    what do I need to do to make this a V2 ?
    thanks
