Hey, so if you're referring to the orange lines attaching both models, I think all you're seeing is just the travel path of the nozzle in between both objects. Whether the travel box is checked or not these lines will not actually appear in your print. As far as I know they are just a visual representation of what your nozzle is doing during the print.
As @GregValiant mentioned, just toggle off the viewing of the travel path to get rid of them in your preview.
The problem is that they do appear. I've tried printing this several times with different settings and quality. Every time those lines connect the models.
Oh interesting, and its not stringing of the filament in between the models?
Do you have a pic of the issue on the actual print?
GregValiant 1,112
Cura can display two types of travel lines. "Heavy" lines indicate that the travel move is being performed with NO retraction. "Light" lines indicate that there was a retraction prior to the travel.
You can adjust "Max Comb Distance with no Retract" and "Retraction Minimum Travel" to adjust when a retraction occurs. Those Letters are very close together at the right lower "X" and that is also the Z seam so there is a lot of the between-part travel going on there. That one would be tough to tune out as the move is so short. Moving the Z seam may be another option.
Here you can see both heavy lines and the light lines. You will get stringing as a result of the heavy lines, but they aren't extrusions, just "movement without retraction". Note that all the (relatively) long lines are light lines. That's a result of those settings I mentioned.
On 8/3/2023 at 6:42 AM, GregValiant said:Cura can display two types of travel lines. "Heavy" lines indicate that the travel move is being performed with NO retraction. "Light" lines indicate that there was a retraction prior to the travel.
Im going to do another test print going off of what you were saying. Ill post back here when it is done
Just wanted to also add, you mentioned you took a break from printing, if your filament was left out on the machine, it could have absorbed some moisture from the air. Wet filament results in more stringing and could be the cause of what you're visibly seeing on the prints.
GregValiant 1,112
It's hard to tell from way over here but when you are in the Preview screen click on the middle button "Color Scheme" and if "Travels" is turned on - turn it off.
