Flow Rate At Different X & Y Coordinates
Posted · Flow Rate At Different X & Y Coordinates
Hello,
I wanted to know if there was a way to set the flow rate at different X&Y points on the same layer? Say that I need different percentage when an infill and a flat surface are on the same layer.
