Hi thanks for the reply both options did not do the trick. but i found out that is you enable a feature it can show allot more options. (i allways used a other slicer before)
but i changed the support overhang angle to 30 degrees so the support would hold on to it better and it worked perfect. it also did not curl up anymore.
GregValiant 1,491
There is no option to change the direction that the nozzle approaches the overhang.
If you enable "Z-Hop on retraction" then if there is a retraction prior to the travel move the nozzle will move up to clear it. The height of the Z-hop is adjustable.
If you enable "Avoid Printed Parts When Traveling" the nozzle should go around the overhang. The "avoid" distance is adjustable.
You might be able to to adjust the Combing Setting but it's usually one (or both) of those other two that works best.
