Ultimaker Breakaway - Unable to set for Support Extruder?
LePaul
Go to solution Solved by Enigma_M4,
Posted · Ultimaker Breakaway - Unable to set for Support Extruder?
I have a weird issue with a slice I am working on.
When I have the second extruder set to BB 0.8 and Ultimaker White Breakaway, under the Support section, I am not getting the Set Extruder option for the supports.
I've verified the extruder is not disabled.
Am I missing something really obvious? 😀
    Well, I cleared everything out, restarted and this time I had the ability to Enable the extruder.
    Something seems wonky there?
    When I was able to select it, I get a warning about the profile
    However, it's back...so I'll press on.
    • Solution
    it's the BB Core, which is only dedicated to PVA.
    For Breakaway, use the AA Core, as for any other (non-abrasive) non-PVA material.
    Regards
    On 8/15/2023 at 1:03 PM, Enigma_M4 said:
    Regards
    Thank you for this, I had the AA08 in there and it didn't like that.  AA04 is in now and working with the AA08 in the other extruder.  It is printing very nicely now!
