Spiralise doesn't support horizontal surfaces, since it's specifically for printing just the outline. Probably more importantly, spiralise doesn't let you use supports since it's just doing one continuous movement, if it had to stop and move to print a support it would create a Z seam, which would defeat the purpose of spiralising.
You can create a closed object, but the top can't be a flat surface, and it would need to be pretty steep since you have only the adhesion of the filament to support itself as it gets smaller (so moving in by less than your line width each layer... time to get the giant nozzle out).
- 2
derPotz 0
anybody...?
