ABS with breakaway, 0.8+0.4 core
Posted · ABS with breakaway, 0.8+0.4 core
I have a rather large print that im doing in ABS. I would like to use 0.3 mm layer height so for the model i will use 0.8 mm core. But since breakaway is only compatible with 0.4 mm (i also only have 1 0.8 atm), is it okay to print 0.3 mm with the 0.4 core for the support?
