4 hours ago, Slashee_the_Cow said:Hello thanks for your prompt response.
- I would like to specify that I haven't upgraded the software to 5.4.0
- I would not adjust the settings of "Wall Ordering to "Outside to inside"" Since most of my designs have overhangs.
- I will try over extrude outer wall slightly as suggested but have a hunch that it might worsen the overall print.
- I am already printing outer walls at 30mm/sec. So i guess this setting has nothing to do with my current scenario.
I am scratching my head around and i found something specious in my setting. I have enabled Coasting. To reduce the stringing. Is this is the culprit setting. I will try some other prints with this setting off. Meanwhile, i am open to more suggestions.
Thank you Community!
Slashee_the_Cow 421
Standard disclaimer right now around here: Cura 5.4.0 has bugs. Use 5.3.1 unless you really need something that got added in 5.4.
As for your problem: in the profile settings, under Walls try setting Wall Ordering to "Outside to inside" . This prints the outer walls first (better for accuracy and helps make sure inner walls or infill don't poke through, main disadvantage is that it makes overhangs much much harder).
If that doesn't fix it (please try a print after changing the wall order and using Cura 5.3 before you resort to these):
Paranoid idea #1: Overextrude the outer walls just a teensy bit by increasing Material > Outer Wall Flow, but you'd probably want it like 105%, max (very very rarely do I come across a situation where adjusting this helps, but I do increase it on the initial layer in my standard profile just to help adhesion).
Paranoid idea #2: Slow down the printer while doing outer walls under Speed > Print Speed > Wall Speed > Outer Wall Speed. Can help reduce the effect if there's any bumps or knocks while it's printing an outer wall (where it's going to be the most visible) but again, don't change it too much or the extruder might start to clog up from constantly changing flow rates for different speeds.
