Confusing Linux Error
WylieM
Posted (edited) · Confusing Linux Error
Hey guys, this is my first post here. I've been running Cura on my Chromebook (Through Linux, I just updated to the newest version) for over a year now, with no real issues. I've been doing the same thing to open Cura, enter "ls", selecting my Cura program that I've already given permissions for, and then opening it with the "./" typical command. I would like to add here that I am not a Linux expert at all, definitely a novice. I don't know entirely what is going on, but in the past I've been able to handle small problems. Anyways, the attached screenshot is the result that I've been getting every time I try to open Cura. In case it was a problem with Cura I downloaded the newest version and ran it. It went smoothly until I tried to open a file and clicked the folder icon. Then it crashed. This might be an entirely different and unrelated problem but I was able to open it, if that changes anything. I tried many different things but can't tell exactly what the solution is. If any more information is necessary I'd be happy to give it.
Thank you!
Edited by WylieM
    • WylieM changed the title to Confusing Linux Error
    Running Linux on a Chromebook is more of a "Google wants you to be able to run Android Studio" thing than a "Google wants you to use this as a daily driver" thing so they're not too concerned about making changes which might break other things. I'm pretty sure the Linux development environment that gets installed on a Chromebook is based on Debian (or one of its children). If I'm wrong then these commands will do nothing (probably just give give you an error about not being able to find apt) so not really going to cause any harm (other than me having to do more research).
    First, the simple: just try downloading the appimage for another version of Cura (5.3.1 is a good choice) and see if that works. If not, some more advanced troubleshooting:
    Let's try reinstalling the package it seems to have a problem with (assuming it's installed in the first place, it might have had just libraries needed, in which case there should be no harm installing it)
    apt update
    sudo apt reinstall xcb
    That will fetch a list of the latest packages available, then reinstall the one that's causing the error. It sounds like it might be outside of the system's PATH environment variable, but I don't know, I don't use Linux on my Chromebook much. Anyway, try that, reboot, try Cura again. If that doesn't work, let's go for the kitchen sink approach. Run these commands:
    apt update
    sudo apt reinstall *xcb*
    That will (again) make sure we have the latest list of packages and then it will reinstall (or install if missing, which a lot of them might be) anything with "xcb" in its name. Reboot, run Cura again. See if it works.
    Whether or not it works, it'll probably leave you with stuff you don't need installed. Clean it up with this:
    sudo apt --purge autoremove
    That just uninstalls any packages you don't need (and deletes any configuration files they might have made and their downloads from the package cache). If the system is wrong about you not needing something and it breaks, just run sudo apt reinstall *xcb* again.
    Unfortunately if all that doesn't work... I'm out of ideas for now. I don't really have an equivalent setup to you (my Chromebook is arm64 so a lot of packages aren't available or need to be compiled from source, and on my desktop I'm rocking openSUSE Tumbleweed).
    P.S. You don't need to run ls before you run Cura. All that does is list files in the current directory. Just type ./Ultimaker and press tab (which should autocomplete the filename, or if you have more than one file that starts with that, keep pressing tab until it comes up with the right one).
    Edited by Slashee_the_Cow
    Added P.S.
    Thank you for your insight. I downloaded the newest Cura again, made it a file that I could open, and once again it crashed after i opened it. After it crashed i went to the terminal and saw the following message:
    And so I tried the:
    apt update
    sudo apt install xcb
    multiple times, here is the result:
    after that i tried to run both versions of cura. For the old one, still had the same core dumped message. For the new one, still crashed almost immediately. Next I tried the
    apt update
    which opened up a long list, asked me if I could download some packages, which I replied "Y" to. At this point i was feeling optimistic, but after it took a while to download it said I had no space. I was planning on re sizing my disk and checking storage management, but decided to try my new cura one more time (It's 5.4.0 BTW). As usual it loaded, and I tried to open a file, it failed. I opened it one more time, but instead of pressing the folder icon I went to File > Open Recent and was actually able to load a file. It sliced and in theory I should be fine. I would prefer a permanent fix, but this temporary solution will have to do for now. Thanks again, I really appreciate your effort I wasn't expecting a response, I'm impressed. Thank you.
    Edited by WylieM
    accidentally saved early.
