Offset between nozzle 1 and 2
FDCW
Posted · Offset between nozzle 1 and 2
Hi, I have an Offset between nozzle 1 and 2 and I can't seem to get a good print using both nozzles.
Ultimaker S5, Rev 8.2.0,
I measured between both nozzles and I do have 22mm.
See attached pictures.
pls advise
    I didn't measure the offset, I measured between both nozzles to make sure that the distance was 22mm.
    I did run the XY Cal, twice but does the Cal adjust the offset between both nozzles?
    I though it only checked the XY which is not the issue here because when I use only one nozzle it prints very well.
    PLA in nozzle 1 and natural PVA in nozzle 2.
    I don't like that the PVA is printed on top of the PLA which creates defects in the final print.
