Blue checkmark on Machine name?
luvtofish
Go to solution Solved by ahoeben,
  • Solution
Posted · Blue checkmark on Machine name?
It means that the printer is actively connected to Cura and you can send gcode files to it (as opposed to a printer that is not connected and you have to manually transfer a gcode file to it).
Curse me and my SD card shuttling for not knowing the correct answer. Previous printer I had, aaaaaaaaages ago would only print over USB, so the novelty of the autonomy factor hasn't run out.
  • Laugh 1
