Thanks, that sounds like it could be what causes it.
But I'm still a bit surprised that Creality Slicer (which I believe is based on Cura) could handle this error but not Cura.
Unfortunately the model is downloaded from ThingIVers (https://www.thingiverse.com/thing:4575335), so I don't have the pieces its made of. So modify the angle will be a bit tricky. Luckily the slice from Creality Slicer prints very well, so I won't put any effort into fixing it. I'm just curious why I got the result I got.
Thanks again for enlighten me 🙂
GregValiant 1,318
Here is the backside of the model. When you merged the logo to the circle it protruded through a little and that looks to be because the logo was at a slight angle. Computers notice such things. You can also see that although the model is watertight that it has errors.
Here is that "slight angle". It's why the top of the logo is made up of several layers rather than just one. This may be why the logo doesn't fit into the "hole" which you didn't need. Set the logo onto (or into) the model and merge them.
One of these has been repaired.
