GregValiant 1,261
The mesh names occur whenever the nozzle is going to move to a particular model.
MESH:Belt tensioner adapter.stl(3)
or
;MESH:Belt tensioner adapter.stl(6)
or
;MESH:Bellows.stl for the first instance.
How does Klipper know that a model has failed and should be ignored?
Slashee_the_Cow 279
I'm not familiar with Klipper so I can't fully speak to its requirements, but Cura does label objects in gcode output by default. Is it possible it labels them in a way Klipper doesn't understand? If so it might be possible to fix it in a post-processor (though I'd need to see the Klipper documentation for it). If it's supposed to work straight out of the box in Cura but doesn't then that's an issue you should probably take to the Cura Github.
