Thanks for your response. I think I get it now,
I may have been overthinking the issue of using the input line as the editor.
Sooo, the input window size cannot change without modifying the QML code (To much work for now), but if I cut and paste from an editor (like word or notepad) I can paste multiple lines simultaneously into the input window, I just cannot see the line brakes or do much in the way of editing the lines other than seethe single string without newlines (although the newlines are there when I use the inputted data), so no need to add any extra “\n” at the end of each line, is this correct?
ahoeben 1,951
This is not currently supported in the Post Processing plugin.
You can use any string you want, and replace it with a newline in your postprocessing code. However it will still be in a single line in the interface.
