The model seems to be too thin in the area where there's a hole.
There are a couple of things that can be done about this:
Enable the "Print Thin Walls" setting. This will let the printer use thinner lines to print very thin parts, although they might become wider than the model intends them to be.
Reduce the line width. If you're printing something that has thin walls or webbings, make sure that the line width is slightly smaller than the minimum width of that part. However reducing the line width too much may cause underextrusion due to insufficient flow. To be able to reduce the line width further, you'll need to use a smaller nozzle.
Add some horizontal expansion to the print. This makes the entire model wider on all sides, including the thin parts. They become less thin that way, so that they may now be printed. This does of course also ruin any dimensional accuracy and detail of the print since everything becomes thicker.
Consider adjusting the model to the print, by making every piece at least as thick as your line width.
For the record, "rendering" normally refers to showing something on screen. The issue here is not showing the preview on screen, but "slicing" your model (creating a toolpath from your 3d model with your selected settings).
ahoeben 1,952
Jasvijay 0
Thank you, print thin walls seems to have done the trick with rendering, will share print results once its done 🙂
