Well, I'm not saying you're a crazy old coot, but I just loaded it in 5.5 beta 1, 5.4 and 5.3.1 and (in the simulation animation, at least), they all printed the brim the way you're describing the new behaviour - left first.
BUT - I think I have an explanation.
I noticed you're getting so close to the edge of the build area that some of the brim just isn't being printed. I tested by both shrinking the object and (after bringing it back up to normal size) decreasing the brim (in this test to 5mm) so that it all fit in the build area. In both of of these situations the brim printed the way you'd normally expect - starts in the corner and does laps around the whole thing.
My guess is that because it can't do whole laps (because that would leave the build area) it's going back and forth up the left side as far as it can - to both edges of the build area - until it reaches the point where it's close enough in that it can do completely laps. It then prints the same amount on the right side (to even it up) and can now do normal laps since its path does not leave the build plate.
Slashee_the_Cow 271
